Header TOPQ7925/6
FL
Header TOPQ7925/6
Bax: I've been told that this item is no longer available. Is this correct? I also understand that the TOPQ7925 and TOPQ7926 will both work for the G series Suepertigre 75. Is this correct? If discontinued, any replacment headers available?
Ed
Ed
FL
RE: Header TOPQ7925/6
Bax: My understanding is that TOPQ 7925 and 7926 are both for Supertigre engines. The 7920 is for OS engines. I have a ST G-75 engine.
Are the 7925 and 7926 both discontinued with no replacment by Top Flite?
FL
With further investigation, it appears that the 7925 header is made for the S series of Supertigre engines, which means that the mounting bolts pass through the header and screw into the engine crankcase. The 7926 header is made for the G series of Supertigre engines, which means that the mounting bolts pass through the engine crankcase and screw into the header. I believe that both have the same, proper dimension from mounting bolt to mounting bolt. So I should be able to use the 7925 on my G series of Supertigre engine. Using the 7925 on the G series will require longer bolts that will pass through the header and be held on with locknuts.
