GP PT60
GP PT60
Ihave looked at several pages in the forum and see nothing about the PT60. Ihave had 2. The first was back in the late 80's. Icrashed that one at full throttle into hard clay. Total destruction. Pilot error. But Iflew about 2 dozen flights before Idid that. My current 60 flew many times around 6 years ago without a problem. Now I have removed the Monokote and am covering it with Koverall and dope. The finish looks alot better so far. Icant wait to get it back in the air in less than 30 days. Ijust wanted you all to know that it is a great flying plane and easy to build. Since it is so large it is easy to see at altitude. Iuse an OS61 and Ihave lots of power. So if you are considering a trainer, the PT60 is a very good choice. IMHO.
RE: GP PT60
Hi Bax
Do you know difference between the Great Planes Trainer 60 and their newer PT60?
I had the older and now the newer. I also got a Little Tony. What can I say. I love Great Planes products.
RE: GP PT60
The Trainer 60 and PT-60 are completely-different airplanes that were designed by different people.
The Trainer 60 was a high-wing, tri-gear airplane with a symmetrical airfoil. It had a 65" wingspan, and was designed by Joe Bridi.
The PT-60 is a high-wing, tri-gear airplane with a flat-bottom airfoil. It has a 71" wingspan and was designed by Craig Golema.
My Feedback: (14)
IN
RE: GP PT60
I have the Old Trainer 60 planes, but no manual. I wanted to buid because of the symmetrical airfoil. I looked on the net for a manual, but no luck. I did check with Great Planes and a copy canbe made for $15.50 shipped. It may take 4 to 6 weeks to get here if I go that route.
If some one has the old Trainer 40 or 60 manual, Could it be scanned and e-mailed to me?
I built the PT-20 and bought a ARF PT-40.
The manual I want is for the Joe Bridi design.
Does anyone know where to look?
Kevin
Kevin
My Feedback: (20)
RE: GP PT60
ORIGINAL: Bax
The Trainer 60 was a high-wing, tri-gear airplane with a symmetrical airfoil. It had a 65'' wingspan, and was designed by Joe Bridi.
The PT-60 is a high-wing, tri-gear airplane with a flat-bottom airfoil. It has a 71'' wingspan and was designed by Craig Golema.
RE: GP PT60
ORIGINAL: kconn3
The manual I want is for the Joe Bridi design. Does anyone know where to look?
Kevin
Kevin
