axe cp 2.4 main blades
Looking for replacement main blades that are not original wooden plastic reinforced blades that come on the model from the manufacturer. Are there any suggestions or has anyone tried foing this?
KS
RE: axe cp 2.4 main blades
There should be plenty of choices around. I own the old/original Axe CP, and I've tried several different blades on there with mostly nothing but success. If you're trying to get away from wooden blades, there are a few carbon fiber options out there. There are also several types of plain old plastic blades, too. My favorite set of blades were a set of wooden blades that approximated T-Rex blades. An online Australian store carried them. Ultimately, however, I went back to the stock blades because they were much less of a hassle to get, and they had the least amount of fuss, in terms of tracking.
I suggest searching by the dimensions of your stock blades and trying out whatever you find that comes close enough.
