Helimax This is for all your Helimax questions and comments.
MX400 Problem.
Old 01-09-2007, 07:47 PM
Philng
Default RE: MX400 Problem.
I figured out why that one blade was moving, there was a screw missing in the head which allowed the see saw to move that much.
Old 01-12-2007, 05:05 PM
Philng
Ok, just had a chance to test it but it has a major problem, the tail isn't powerful enough to keep the helicoptor still. I let the pitch of the tail go out all the way but it still doesn't have enough power to keep the tail still, the heli spins to the right after getting it off the ground.
Old 03-03-2007, 10:15 PM
pilotjoe50
I just bought my first mx 400 pro, does the DX6 work good and I am told a gy240 gryo will work. What gyro are you using?
I have been flying the blade cp pro with the futaba g90 gyro, but I am using the futaba radio with it.
Old 03-04-2007, 09:36 AM
Philng
I'm using the same, the futaba 240 gyro.
Old 03-04-2007, 09:49 AM
pilotjoe50
Are you using the DX6 radio with that?
Old 03-04-2007, 08:16 PM
  #31
Philng
naw, futaba 6exh
Old 03-24-2007, 02:13 PM
  #32
whattheheli
are you sure you have gyro set right?? the leading edge of the tail rotor should move in the same direction of nose movement meaning if the nose goes left the leading edge points to the same side of the heli !
