Go Back  RCU Forums > RC Helicopters > Electric RC Helis > Helimax
Reload this Page >
helimax spins in cirle
Helimax This is for all your Helimax questions and comments.
Old 03-05-2007, 07:46 AM
markzr7
Default helimax spins in cirle
Hi I have a question on the helimax
I had A crash not to bad
Now the copter wants to spin in circle when hovering
I ck and every thing seems in order any imput would be great
thanks mark
Old 03-05-2007, 08:52 AM
Rotor13B
Default RE: helimax spins in cirle
ORIGINAL: markzr7
thanks mark
How bad was the crash?? Did anything break? Which way is it spinning? Does the tail still spin up at about half stick? Do you have a pic of the heli since the crash?
Old 03-05-2007, 09:12 AM
markzr7
The copter spins left
I dont have any pics
can a person put the blades on wrong ????
Old 03-05-2007, 09:15 AM
markzr7
she spins to the left
could a person put the blades on wrong ?????
Old 03-05-2007, 09:58 AM
nzak
I would check to make sure the gears between the tail motor and blade are meshing properly. Could be just tight enough to spin, but slip as it gets faster. Mine did that after a boo boo landing
Nick
Old 03-05-2007, 10:06 AM
Rotor13B
it's possible to put them on backwards. The blades spin clockwise, The tapered edge is the trailing edge(the side with the notch next to the blade grips). Both blades and the flybar should be this way.
Old 03-05-2007, 10:22 AM
markzr7
THANK YOU
Old 03-05-2007, 10:25 AM
Rotor13B
No problem, Let us know how it goes.[8D]
