Go Back  RCU Forums > RC Helicopters > Electric RC Helis > Helimax
Reload this Page >
Axe CP main shaft collar
Helimax This is for all your Helimax questions and comments.
Old 03-11-2007, 01:09 PM
leica1
Default Axe CP main shaft collar
Hello, I have a problem reinstalling the main rotor shaft on an axe cp. Does the main shaft collar (with the setscrew) go above or under the top frame member? That is, under the swashplate or under the frame? When installed above the frame, the main shaft can move upwards until the main gear seems to make contact with the upper frame. Your answers are highly appreciated.
Jimbo
Old 03-11-2007, 02:46 PM
quickster47
quickster47's Avatar
Default RE: Axe CP main shaft collar
Jimbo,
The top collar goes underneath the top part of the frame where the top bearing is located. The main gear is inside the frame on the bottom and becomes the other piece that keeps everthing tight and running against the bearings.
Carl
Old 03-11-2007, 02:48 PM
outtamyway
It goes under the upper bearing. Don't forget to put the spacer on the shaft just above the lower bearing.
Old 03-11-2007, 09:47 PM
leica1
Thanks guys, my heli went awry and hit the ceiling, hard. But, due in no small part to your help, I fixed it. Additionally, the main wire running from the e-board to the battery (or the other way around) broke and I delicately soldered it back on. Whew, no new e-board, at least.
Leica1
