Go Back  RCU Forums > RC Helicopters > Electric RC Helis > Helimax
Reload this Page >
Helimax just spins no lift
Helimax This is for all your Helimax questions and comments.
Old 03-13-2007, 06:40 AM
markzr7
Default Helimax just spins no lift
Hello everyone could use some help
My helimax dosen't lift just spins (very fast)
It seems that the head speed is proper but no take off
CK battery CK motor mounts, radio servos ect.
no pitch any HELP would be great
Thanks mark
Old 03-13-2007, 07:01 AM
Rotor13B
Default RE: Helimax just spins no lift
Do you have your blades on correctly? Head spins clockwise, Thin side of the blade is the trailing edge.
Old 03-13-2007, 07:17 AM
markzr7
I had it to the lhs seems the blade are ok
they didnt have time to ck.
Old 03-13-2007, 07:31 AM
outtamyway
unplug the motors.
power up the transmitter and helicopter.
move the left stick to full throttle.
level the flybar and ensure that the blades are straight in relation to the axis of the grips.
How much pitch do your rotor blades have now?
Old 03-13-2007, 08:40 AM
markzr7
I will try this I am also going over to another lhs
I'll let you know
thanks mark
Old 03-13-2007, 09:23 AM
PilotLight
PilotLight's Avatar
Is it New, or did you rebuild it?
Some of the photos in the manual show components backwards in the exploded view. The ball on the blade grips go to the trailing edge of the blade. For higher pitch, the servos move DOWN and the trailing edge is moved down, creating a positive angle of attack on the blades.
Old 03-13-2007, 10:56 AM
markzr7
Thanks for the help ( new at xmas)
I'm new to all this I will ck the pitch
with my lhs this way I dont mess something else up
I fly planes
trying to fly heli lots of fun & LOTS TO LEARN
thanks a lot
mark
Old 03-13-2007, 10:59 AM
edpogi
check your swashplate make sure it did not seperate. i changed mine to the cnc and it wouldn't hover just spin. i knotice that mine was seperated so i bent the inside so it will hold.
Old 03-13-2007, 06:08 PM
markzr7
Hi thanks for the help it turns out
the blade tracking was way off
30 sec back in the air talk later
