Helimax This is for all your Helimax questions and comments.
EZ Adjustment
Old 03-17-2007, 08:37 AM
slc71
Default EZ Adjustment
Since my CP is out of commision I pulled out my EZ to mess with and my problem is when I get off the ground it wants to go backwards.
If I push the stick forward all the way it goes into hover.
What adjustment should I make for this?
Also is the swashplate supposed to be level on these things?
Old 03-20-2007, 09:33 AM
gatorz1
gatorz1's Avatar
Default RE: EZ Adjustment
Check your swash plate it's probably separating, mine did the samething and it wouldn't fly forward. There shouldn't be anymore than an 1/8th of an inch of separation from the top of the swashplate and the bottom. A quick way to see if it is the swashplate is to get a couple of needle nose pliers and squeeze the swashplate together, if it flies forward for a short time and then stops it's a bad swash and will need to be replaced. Hope this helps.
