Go Back  RCU Forums > RC Helicopters > Electric RC Helis > Helimax
Reload this Page >
heli max spins in circle
Helimax This is for all your Helimax questions and comments.
Old 03-18-2007, 02:24 PM
markzr7
Default heli max spins in circle
Hi need more
help with axe cp
The heli just spins very fast
can't get the tail to sit still
lifting good but spining
any help
Old 03-18-2007, 03:47 PM
SchoooBaka
SchoooBaka's Avatar
Default RE: heli max spins in circle
Is the tail rotor spinning?
Old 03-18-2007, 04:02 PM
markzr7
The tail spins fine
I can't stop the spining of the whole heli
Old 03-18-2007, 04:17 PM
SchoooBaka
SchoooBaka's Avatar
with the trottle only up enough to spin the main blades, but not enough to take off, manipulate the rudder control.
Does the heli react accordingly? Does the speed of the tail rotor change?
Old 03-18-2007, 04:23 PM
markzr7
yes
Old 03-18-2007, 04:40 PM
SchoooBaka
SchoooBaka's Avatar
Hmm, the tail rotor should counteract the spinning.
What direction does the helli spin?
Does the speed of the spinning change with rudder inputs?
Is the trim set properly?
Did you mess with the adjustments on the 3 in 1 board?
Old 03-18-2007, 04:58 PM
SchoooBaka
SchoooBaka's Avatar
Is this you're first heli?
You do know that you have to control the tail with the left stick right?
No matter how much you mess with trim, you will always have to fly the tail.
If it spins clockwise, move the left stick to the left until it stops spinning; counterclockwise, move left stick to the right.
Old 03-18-2007, 05:22 PM
markzr7
I didn't the my lhs did
It flew much better before
any tips thanks
Old 03-18-2007, 05:27 PM
SchoooBaka
SchoooBaka's Avatar
I would hope the lhs knew what they we're doing. If they turned the adjustments too far, it could have damaged the pot's on the board.
Some people have also had problems with the 3 in 1 board.
You could try contacting helimax to send you a new board, it should be covered under warranty.
Old 03-18-2007, 05:31 PM
markzr7
THANK YOU
Old 03-18-2007, 05:37 PM
SchoooBaka
SchoooBaka's Avatar
No problem.
Keep us posted on what happens.
Old 04-03-2007, 06:36 AM
canmore flyer
hey...i had the same thing with mine,,,a good chance is your tail motor might not be running at full power...i put a new one in and now it works great..
