K&S Rotor balancer for AXE CP
WI
The pins that the blades mount to are to big. Are any of you using this balancer? If so what are you using for an alternitive pins to balance the blades on an AXE CP?
Just a thought I bought the heli-max balancer and all the adapters in it were too big also so I took the 2.5mm adapter and cut the pins off redrilled and put 2mm screws though it.Just an idea.
