Go Back  RCU Forums > RC Helicopters > Electric RC Helis > Helimax
Reload this Page >
How to tighten flybar shaft on AXE CP?
Helimax This is for all your Helimax questions and comments.
Old 03-29-2007, 02:37 PM
rwj
Default How to tighten flybar shaft on AXE CP?
I had a mishap when my screw came off the grip that holds the bearings in. It exploded in mid air. I have it all together now and I can't get the flybar shaft to tighten up so I can level the paddles. What am I doing wrong or what part am I missing?
Old 03-29-2007, 03:05 PM
PilotLight
PilotLight's Avatar
Default RE: How to tighten flybar shaft on AXE CP?
They look like Wheel Collars. Small metal donut with a hex screw in one side.
Old 03-29-2007, 03:30 PM
rollingball
rollingball's Avatar
I've had the same problem to find out the flybar carrier has 2 ears that pretrude out so that the wheel collars can pinch the rod. When they break off the whole assembly will rotate.
Time for a new flybar carrier.
Or you can glue it but it won't last long
Old 03-29-2007, 03:57 PM
Heliko
Heliko's Avatar
I had to replace my flybar carrier too. I was surprised to find I really had to crank down on the collars to get the flybar tight enough to not rotate in the carrier.
Old 03-29-2007, 05:16 PM
rwj
Thanks I have a new one. I will put it on.
