Go Back  RCU Forums > RC Helicopters > Electric RC Helis > Helimax
Reload this Page >
Convert Helimax Axe CX to mode 1
Helimax This is for all your Helimax questions and comments.
Old 05-12-2009, 12:50 PM
sportflyer-RCU
My Feedback: (35)
Default Convert Helimax Axe CX to mode 1
Has anyone tried to convert the Helimax Axe CX from the default mode 2 to mode 1 ? Switching the TX is easy but what about the Heli side . Is it as easy as swapping the receiver channels? Tks
Old 05-12-2009, 02:25 PM
pilot143
pilot143's Avatar
Default RE: Convert Helimax Axe CX to mode 1
mode 2 to mode 1? as in swapping the sticks on the tx?
if so, what is to change on the heli side? its still the same right? ail is still ail... roll is still roll... all your doing is swapping the sticks from left to right and right to left.
sorry if I misunderstood or am not seeing something the right way.
Old 05-12-2009, 05:01 PM
sportflyer-RCU
My Feedback: (35)
Mode 1 : Throttle and Aileron on right stick, Elev and Rudder on left stick. Mode 2 = Elev/Ail on right stick and Throttle/Rudder on left stick. So for older TX besides swapping the spring/ ratchet from left to right , I also have to swap the Elevator and Rudder connections to the receiver because it cannot be swapped in the TX. However for newer TX models the channels are automatically swapped in the TX when you select mode1 or mode 2 electronically. . I am just wondering whether this function is available in the supplied HELIMAX Axe CX transmitter either through the setup menu or a mode1/mode2 switch.
