novus cp tail boom
novus cp tail boom
I have the novus cp and i broke the tail boom. if you didnt know the wires run through the boom on this model with no connectors for easy removal so you have to cut them and re soder them. i was wondering if i could run the wires down the side of the boom instead of through it so that if i break the boom again it will be easier to replace.
RE: novus cp tail boom
Yes, on the Novus CP the tail motor wires run inside the boom, you will have to unsolder the wires at the tail motor to get them out, also you can run the wires outside the boom, just tape them on.
Walkera 4g3 & 4#3b tail booms are the same as the Novus CP booms.
Shadow
Shadow
