Go Back  RCU Forums > RC Helicopters > Hirobo Support Forum
Reload this Page >
Hirobo electric Chinook question
Hirobo Support Forum Greg Gomes of MRC/Hirobo is your host. Ask all your Hirobo questions here!
Old 02-17-2012, 11:27 AM
rva1945
Default Hirobo electric Chinook question
This is the Hirobo tandem rotors Chinook:
[link]https://www.youtube.com/watch?v=OFEfTGEe2xU[/link]
It seems to be electric.
Both rotors are engaged to the same gears, as it can be seen when turning at lower speeds, or I am wrong? If so, then how does the heli change heading? Does the rudder channel work on the gyro to make the heli spin?
Robert
Old 02-17-2012, 12:52 PM
BarracudaHockey
BarracudaHockey's Avatar
Default RE: Hirobo electric Chinook question
Yes, they are synchronized through the transmission. Bad bad things happen when they de-synchronize.
As for rudder control (yaw) there's a pretty complicated electronic mixer used for those things but the end result is, when you give left "rudder" the forward head applies a bit of left cyclic, and the aft head applies a bit of right cyclic, and the result is the heli pivots on the yaw axis.
Old 02-17-2012, 03:00 PM
rva1945
Thanks!
Now, do you have any idea about the price?
