Hirobo Support Forum Greg Gomes of MRC/Hirobo is your host. Ask all your Hirobo questions here!
xrb help
Old 09-02-2007, 12:11 PM
keith123102
Default xrb help
how do you test a crystal in heli
Old 09-04-2007, 12:05 PM
mrc-hirobo
Default RE: xrb help
Plug it in and do a range check per your radios instructions. Usually it is 33 paces, but if an XRB it is probably shorter as the radio does have reduced power.
If you lost radio on yours, Check the radio selector pot to be sure it is in the Futaba setting when using the stock radio.
shake the crystal, if you hear a rattle it needs to be replaced.
Also remove it and make sure the pins are straight. If bent they may not be inserting into the "pod" correctly.
Jeff
Old 09-11-2007, 04:22 AM
keith123102
when i turn the heli on and the transmitter on all the lights work on both but it will not respond at all
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
