Go Back  RCU Forums > RC Helicopters > Hirobo Support Forum
Reload this Page >
Hirobo HGE-20EH Gas Engine
Hirobo Support Forum Greg Gomes of MRC/Hirobo is your host. Ask all your Hirobo questions here!
Old 06-13-2008, 06:55 PM
rudiix
Default Hirobo HGE-20EH Gas Engine
Hi,
I wonder if anyone knows where I can get a copy of the Hirobo HGE-20EH engine manual. This is the earlier 20cc version of the gas engine. Mine has gone missing sometime within the last twenty years.
Hope some one can help.
Old 08-26-2008, 04:37 PM
Unclepeter66
Default RE: Hirobo HGE-20EH Gas Engine
Did you ever get a copy of this manual? I have a complete copy including all the exploded diagrams etc. I will be happy to send you a copy of them.
Old 09-06-2008, 06:01 PM
rudiix
Hi unclepeter66.
Thanks very much for the offer. which manual are you referring to? If ot's for this engine I would love a copy.
Hope to hear from you soon.
Regards
Rudy
Old 09-08-2008, 03:29 PM
Unclepeter66
Hi Rudy
The complete manual + exploded diagrams for the Hirobo HGE-20EH engine. This is the original gas engine supplied with the Hirobo Huey heli from the early 80's. I believe this was later replaced by a larger 25cc engine due to it being under powered. It has the light green fan cover.
If it sounds like the correct one let me know. Maybe with it you can figure out why my engine won't run properly
Old 09-11-2008, 12:48 AM
rudiix
Hi Uncle Peter66
Yes that's one, I would love a copy of this and yes it has the light green fan cover. I have the orginal Hirobo Bell 47 G2 Manual and Blue Prints and this would complete the set.
What sort of engine are you having problems with? I'm certainly no expert but will help you all i can.
Thanks and Regards
Rudy
Old 09-11-2008, 03:17 AM
Unclepeter66
Hi Rudy
I will need your address.
Email it to me at [email protected]
I am having problems with this very engine in the Huey. If the weather stays dry for more than 5 minutes at the weekend I am planning on clamping the Huey to a table outside, getting underneath the heli and trying to set it up whilst it's running under load. I am going to try reducing the oil content of the fuel from 20/1 to about 25/1 following someones suggestion. I also think the adaptor from the silencer to the down pipe is very restrictive so may look at getting this opened out. Does this engine in your 47G have sufficient power to get the heli into the air and maintain a hover?
Pete
Old 09-11-2008, 06:09 AM
rudiix
Hi Pete,
I have had this Heli for over twenty years now and it has probably only seen about 3 hours hover time. until i put it away. Yes the engine had plenty of power to hover tho I did not try to fly it but have seen one other identical heli fly and hover with no problems.
As far as the fuel to oil ratio goes I can't see that it will make the difference between hovering or not, but I could be wrong and think it is worth adjusting it to make sure. I did run mine on 25 to one with no problems.
What's happening when you try to hover? Two stroke engines are fairly simple and it may be just a case of setting your carb right tho with this engine it does have timing advance which I have not had a need to play with. It's the cable that goes down into your engine near your throttle, is it hooked up. Your running adaptors in your exhaust system....is this stock or an after market addition? I set mine up as best I could to all stock settings and it was reliable but if you have deviated away from this in your exhaust it could be worth investigating further. Stick with it and I'd be curious to know how it goes. It's probably just one simple thing that is causing you the problem.
Regards
Rudy
Old 12-06-2009, 04:50 PM
lawrencelkl
Hi all,
i have recently obtained an old hirobo Bell 47G . May i know if you can help with the engine manual? as i does not have one and thsi is my first gasser.
thanks a lot in advance!!
Lawrence
Old 12-07-2009, 04:36 PM
Unclepeter66
Hi,
Yes I can supply a copy of this for you. Will an electronic copy suffice or do you need me to post one.
Peter
Old 12-07-2009, 05:57 PM
lawrencelkl
Hi Peter,
Thanks for your help! If the electronic copy is clear to print out, then please send a copy and I can print out myself.
I will PM you for my email.
Thanks a lot!!
Best Wishes,
Lawrence
Old 03-15-2010, 04:01 AM
lawrencelkl
Hi Peter,
Thansk for your help abt the manual. my hirobo bell 47G flown first time yesterday!
http://www.youtube.com/watch?v=4J57qiOQzdA
Cheers
Lawrence
Old 08-13-2012, 08:22 AM
igoren
My Feedback: (23)
hi, is anybody can help me to obtain a manual for the HIROBO HGE - 20EH . i have the bell uh - 1b iroquois gx - 20 1/7.4 scale by hirobo . never been flown built in japan , it has actually the upgreded engine GE - 250E by kioritz corp. maid in japan# 0001362. it is 25 cc motor. i belive the manual will be the same.
any help ,
thanks
Isaac
[email protected]
Old 08-14-2012, 01:50 AM
lawrencelkl
Hi igoren,
I have it somewhere, but a hard copy. let me find it and will let you know.
cheers.
Lawrence
Old 08-14-2012, 09:43 AM
igoren
My Feedback: (23)
THANKS, LAWRENCE.
Old 08-15-2012, 12:11 AM
lawrencelkl
Hi Igoren,
I have found my hard copy engine manual and scanned it at the office this morning. I have send this pdf to your email as above. Please check it.
I obtained this from Unclepeter66 (Peter) as you can see above so ALL credit goes to Peter!
enjoy flying and do share some of your heli photos/videos with us!
cheers.
Lawrence
Old 08-15-2012, 12:19 AM
lawrencelkl
Hi Peter and Rudiix,
how are your Hirobo helis? the 'latest' video i have for my hirobo Bell 47G is here.
http://www.youtube.com/watch?v=PWlZU...hannel&list=UL
this was with the symmetrical blades, which hover ok in UK but when I brought heli to Asia with warmer and more humid weather, it did not lift at all. I have then changed to semi-symmetrical vario blades and it make a BIG difference! with same engine settings, it lifted half throttle!
so, if you are having lifting problem, try semi-blades if you have not done so, just some sharing.
Cheers
Lawrence
Old 08-15-2012, 11:51 AM
igoren
My Feedback: (23)
THANKS AGAIN LAWRENCE, AND CREDIT TO PETER ( WHO FORWARD THE THE MANUAL TO LAWRENCE ) WHAT WE WILL DO WITHOUT RC - UNIVERSE . LOVE YOUR VIDEO OF THE BELL , ONE OF MY FAVORITE HELLI.
I WILL POST SOME PICTURES LATER OF MY RECENT PORCASE OF HIROBO IROQUIS BELL 204 . IT IS PROBABLY 20 - 30 YEARS OLD , NEVER BEEN FLOWN , PRO BUILT IN JAPAN - I WAS TOLD. I WILL POST SOME PICTURES BEFORE IT IS GOING INTO SOME " SIMPLE / MAJOR " CHANGES. 1. FOUND OUT WARPED MAIN WOODEN BLADE ( 800 MM ) - GOT NEW ONES CARBON FIBER $ 150.00 , OUCH , LIKE TO REPLACE THE WOODEN TAIL BLADES 120 MM - TO CARBON FIBER - 120 MM.
SEND LIGHTLY THE ORIGINAL PAINT , ADD FEW.... RIVETS ( PROBABLY SEVERAL HUNDREDS ) , CHANGE THE PAINT SCHEME , CHANGE RX TO 2.4 , I AM USING JR 10X HELI. , SERVOS ? NOT SURE. GIRO - LOVE TO HAVE 3 AXIS .WILL SEE.
THATS FOR NOW , AND AGAIN THANKS
ISAAC
Old 08-15-2012, 12:04 PM
Unclepeter66
Hi guys,
Glad you found your copy of the engine manual, mainly because I can't now find the original manual now! Given up on the Hirobo engine anyway and haven't touched the heli for ages. Just about to try a Zenoah engine instead. One of the guys at the heli club owns an engineering company so is going to make me the adaptor plate to suit.
Hope you get yours working.
Old 08-15-2012, 01:45 PM
igoren
My Feedback: (23)
HERE WE GO , STILL NEED TO ADENTIFY THIS ENGINE - IT LOOKS THERE ARE NO WIRES FOR ELECTRONIC EGN. NEED SOME HELP
THANKS
ISAAC
ID:	1792303   Click image for larger version
ID:	1792304   Click image for larger version
ID:	1792305   Click image for larger version
ID:	1792306   Click image for larger version
ID:	1792307   Click image for larger version
Old 08-15-2012, 01:59 PM
igoren
My Feedback: (23)
SOME MORE PIC'S
ID:	1792309   Click image for larger version
ID:	1792310   Click image for larger version
ID:	1792311   Click image for larger version
ID:	1792312   Click image for larger version
ID:	1792313   Click image for larger version
Old 08-15-2012, 02:02 PM
igoren
My Feedback: (23)
MORE PIC'S - AND THE LAST 2 WILL BE MY NEW PAINT SCHEME
ID:	1792318   Click image for larger version
ID:	1792319   Click image for larger version
ID:	1792320   Click image for larger version
ID:	1792321   Click image for larger version
ID:	1792322   Click image for larger version
Old 08-16-2012, 12:19 AM
lawrencelkl
Wow! Isaac,
really a super cool heli. will be looking nice in the air with the new color scheme!
As I posted earlier, would recommend semi-blades to generate higher lift and can fly at lower scale like rpm.
I can see yours has the same metal flybar center piece as mine. which is at least 20 years + too.
seems like a great project, and please do keep us posted with your progress....
good luck!
Regards,
lawrence
Old 08-16-2012, 06:59 AM
igoren
My Feedback: (23)
Tanks, Lawraence I will. send me some close up pic's of your bell if you have , and also any recomondation of the set up and mixing . I have not done it for years , I am using jr 10x for control with 7 ch spectrum rx .
Old 08-16-2012, 07:52 AM
lawrencelkl
Hi Isaac,
Have to be honest with you that I am a real beginner level compared to many others on this forum . But will like to share some thoughts with you for sure.
I have brought my Bell 47 G to Asia earlier this year and hence will not be able to provide close up photos until my next visit.
I got my Bell 47G in an unflown conditions but far from the good conditions of your heli. few points to share:
-about the metal fly bar center piece, I would advise to check thoroughly and be easy at least first time fired up the engine, mine broken together with the one way bearing main shaft after first few times spooling up. A close inspection (i think) revealed that it is due to metallurgy ageing and/or fatigue issues? so, pelase be carefuly with that. Luckily a fellow flyer is kind enough to donate a spare one as Hirobo no longer carry this part.
-I am not sure about your engine but if it struggle to start up and keep running smoothly as mine did initially, a changeout of the carburetor diaphram and gasket kit will change the story! I changed all rubber parts in the carburetor (you can get gasket kit of your particular carburetor by searching online) because all the original ones become stiff (after 20+ years!) hence diaphram cannot pump in the petrol porperly.
-as you said that you are changing to 2.4GHz so that is good. I had really scary inteference with my original FM radio, the servos decided to do their own movements! spark plug in petrol engine can cause severe inteference to FM radio
- I am not sure about your 25CC engine but my and another fellow flyer with same engine concluded that these hirobo 20 cc engines are best when loaded up with high positive pitch on the main blades.
-I use futaba GY 401 as scale does not need latest gyros for 3D etc but still holding the head very very well. of course 3 axis gyro will be good !
-does your engine come with electronic ignition system? if so, here is a forum which Pete shared a lot of upgrading hirobo older's electronic ignition system.
http://www.rcheliaddict.co.uk/hirobo...tml#post886688
all i can think of for now. will post mroe if I can think of any more..
Cheers
Lawrence
Old 08-16-2012, 07:58 AM
lawrencelkl
some photos
ID:	1792592   Click image for larger version
