Go Back  RCU Forums > RC Helicopters > Hirobo Support Forum
Reload this Page >
Evo 50 power switch
Hirobo Support Forum Greg Gomes of MRC/Hirobo is your host. Ask all your Hirobo questions here!
Evo 50 power switch
Old 08-03-2008, 03:07 PM
Default Evo 50 power switch
My receiver switch gets soaked in fuel residue from flying backwards a lot. Does anyone have a trick for keeping it dry?
Old 08-03-2008, 07:27 PM
glydrjocky
glydrjocky's Avatar
Default RE: Evo 50 power switch
I suppose you could do one of three things............
A. Stop flying backwards but that would take all the fun out of it!
B. Mount the switch on the opposite side of the frame.
C. Put an exhaust extention that directs the offending lubrication in a less offensive direction
I consider all components of my Hirobos to be "self lubricated" by an automatic inflight lubrication system.
Look at the bright side...................
At least the switch will never wear out
Old 08-04-2008, 02:14 AM
sfell
My switch lives up on the side of the frame instead of in the factory location. Seems to stay pretty dry there, but I don't go backward much. If moving it doesn't work for you there are a couple options. A. Live with the mess and pray it doesn't cause a catastrophic failure during flight. B. go to a switch that won't care (something sealed for adverse environments). C. clean it, wrap it in latex, and operate it through the stretchy covering.
My two cents.
Sfell
Always fly in the middle of the air, stay away from the edges.
Old 08-06-2008, 12:46 PM
The canopy is acting like an air scoop, directing a flow past the switch, so I think mounting the switch higher would help. But since I don't see a convenient place to put it elsewhere, I think I'll try making a deflector behind the switch instead.
BTW, the switch is not on the muffler side and it still gets an oil build up.
Old 08-07-2008, 01:09 AM
sfell
Are you running your engine too rich?
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
