servos getting hot
hello
I am setting up a new radio system reciever is a jr 921 and the two servos that are giving trouble are both hitecs one is a hs 81 on a gear door sequencer. There are two servos on this sequencer both hs 81s the oneforthe doors gets hot but the one for the gear is fine I have made sure that it is not over stroked even replaced it with another new one it also got hot.
Now later on in the set up i started to work on the flap servos they are hs5645mg and it is hooked up with a y harness and one servo is fine and the other gets hot. Again I replaced the servo with another new one and it gets hot also
I have never had these problems before and not sure what to do about it.
Any help is appriciated
P.s all of this equipment is new
It's not uncommon for servos to get warm with usage but it sounds like something else may be going on. I would test the servos plugged directly into the RX without the sequencers or y harness to see if that makes any difference.
Mike.
Mike.
