Throttle Hold
On the Aurora 9 I set up Throttle hold on switch G to hold throttle at idle for autos etc. If the throttle is above idle when the switch is turned on the throttle continues to follow the throttle stick until the throttle stick is brought back to low. Why? I really do not want to go to full negative pitch to get to throttle hold.
I have tried everything that I can think of! I have set up a HOLD flight condition using switch G with one position off and one ON. I have also set up THOLD and I still can not get the throttle to go to idle from any position using the G switch without taking the throttle stick to low first. I am still using TX version 106 software (I don't have the HPP interface yet). HELP....... I am using a hold flight condition and thold as well, Do I only need to use one of these? I tried the hold flight condition by itself and the G switch worked but only in Idleup1 and not in Normal.
