Which radios can Hitec Aurora 9 buddy box to?
Hi,
Can you tell which radios the Hitec Aurora 9 can buddy box to - is this selectable in programming?
Thanks for your help.
Fly4Fun,
Wayne
Fly4Fun,
Wayne
ORIGINAL: Wayne Miller Hi, Can you tell which radios the Hitec Aurora 9 can buddy box to - is this selectable in programming?
Thanks for your help. Fly4Fun, Wayne
Aurora: Trainer / Buddy system Master & Slave function Set-up.for detail of connections and set up.
Be aware that there may be some problems surface with the newer Futaba 4/6 ch 2.4 Ghz Futaba systems as they do with other Futaba systems.
Futaba should not be used as a slave with Heli as trims/mixes are different.
See also
Aurora A9, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips. {Individual Links often updated}
and sub Section "Trainer (Buddy box) cables - DIY " under
"Buddy Boxes. Servo Leads. Flight Simulator & Interface." at:
Alan's Hobby, Model & RC FAQ Web Links
Regards
Alan T.
Hi Alan,
Thanks, I have a conversion cord from JR to Hitec/Futaba that reorganizes the channels. From what I read, I can assume I can use a JR to Aurora using this cable.
I was hoping the new Aurora 9 would have a programming option to select which Tx you want to make your slave, then just plug in the proper slave cable. I wanted to be able sell my JR but still be able to buddy box to JR or any other Tx I wanted to. It appear this can not be done.
Fly4Fun,
Wayne Miller
Fly4Fun,
Wayne Miller
ORIGINAL: Wayne Miller Hi Alan,
Thanks for your help. Fly4Fun, Wayne Miller
Have tried several methods to operate with JR but no worhtwhile result to date.
You could try adapting GWS - Buddy (Trainer) to Hitec, Futaba, JR & Sanwa( aka Airtronics).,not yet proven.
Alan T.
