Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
Multiplex Micro-IPD 7 channel receiver
Old 10-24-2010, 02:24 PM
jeffie8696
jeffie8696's Avatar
Default Multiplex Micro-IPD 7 channel receiver
Irecently aquired a Mpx Pico and Micro-IPD receivers new. The Pico works awesome, using a Mpx crystal and my JR S400 radio. However with the same radio and crystal the Micro-IPD doesnt work at all.
Idid a forum search and found nothing useful. Help please. Am I doing something wrong? What should I do?
Old 10-25-2010, 09:45 AM
Brendan Lugo
Brendan Lugo's Avatar
Default RE: Multiplex Micro-IPD 7 channel receiver
What frequency band is your Micro -IPD receiver on? 75 Mhz, 72 Mhz, ???
Old 10-25-2010, 11:29 AM
jeffie8696
jeffie8696's Avatar
72
Old 10-26-2010, 09:45 AM
Brendan Lugo
It should have worked then if it were a good receiver. Where did the receiver come from?
Old 10-26-2010, 12:05 PM
jeffie8696
jeffie8696's Avatar
Long story, a retailer friend of mine, Igot a good deal on it but if it doesnt work It is brand new never installed.
Old 10-27-2010, 09:39 AM
Brendan Lugo
Not sure whats going on with it then. If you want to send it in we can take a look.
Old 10-27-2010, 10:31 AM
jeffie8696
jeffie8696's Avatar
Thanks Brendan, it sure isnt doing me any good like it is. Pity really the Pico Ibought at the same time works fantastic!
Old 10-27-2010, 08:31 PM
A.T.
ORIGINAL: jeffie8696 Thanks Brendan, it sure isnt doing me any good like it is. Pity really the Pico Ibought at the same time works fantastic!
Further to Brendan'sposts and not wishing to intrude, check programming plug is not inserted during intial set up.
TXmust be switched on first off last.
Iinitial TX recognition is recommended for most known similar IPDRX, with TXantenna down and held between.5<2cmfrom RX.
Please refer section 4.3 of the Multiplex IPD"Techno Tips" -
"Valid only for Single Conversion Micro IPD" - "avoid extreme signals"
- perhaps EPA of one of your TX channels is to wide.
Copy English Instr. attached in case of need.
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links.
ID:	1524213   Click image for larger version
File Type: pdf
Old 10-27-2010, 08:36 PM
jeffie8696
jeffie8696's Avatar
No the programming plug has never been inserted.
Old 11-01-2010, 08:36 AM
Tony abw60
Hi
You need to check whether its a single conversion rx or a duel conversion.I think maybe the micro is a single conversion rx.
I maybe wrong of course.
It will require the right crystal
Tony
Old 11-01-2010, 12:27 PM
jeffie8696
jeffie8696's Avatar
I have checked and both it and the Pico are single conversion and therefore should require the same crystal. The crystal I used in both receivers works fine in the Pico.
