Hitec CG-340 potensial problem?
RE: Hitec CG-340 potensial problem?
ORIGINAL: perche Hello, i just connected the battery backwards to the CG 340 charger what should i do?Thomas
6. If the charger is attached to the power source "backwards" (in reverse polarity), nothing will happen.
But if the battery to be charged is connected with reverse polarity =
7. If the battery to be charged is attached to the charger "backwards" or in reverse polarity, the entire structure of the Universe as we know it will be substantially altered as time will then run backwards and it will be your fault.
it will be cheaper to buy a new charger..
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
