Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
hpp-22 receiver problem
Old 12-04-2010, 05:21 PM
dredknot
Default hpp-22 receiver problem
Hello,i'm updating to 107,no problem at all with the tx,module or 2 of my 3 receivers,last receiver will not up date,the progress bar gets to 33% and then i get an check connection massage,what should i try and should i even fly with this receiver
Old 12-05-2010, 11:27 AM
A.T.
Default RE: hpp-22 receiver problem
ORIGINAL: dredknot Hello,i'm updating to 107,no problem at all with the tx,module or 2 of my 3 receivers,last receiver will not up date,the progress bar gets to 33% and then i get an check connection massage,what should i try and should i even fly with this receiver
An Optima 9?
A small amount of the 9's won't update for whatever reason. You only need to update it if you plan to use the add on telemetry though, the built in battery telemetry will still work fine without the update. You'll need to contact the service deptartment and we'll figure out the best way to get you taken care of if you need it updated. - Mike.
Hitec Warranty & Service
- Aurora A9, Spectra Pro & Optima - FAQ & Undocumented Features
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
Old 12-06-2010, 07:59 AM
Brendan Lugo
Brendan Lugo's Avatar
Is this an Optima 9 receiver? You will need to contact the distributor in your area to get it replaced if it is.
Old 12-06-2010, 04:21 PM
dredknot
Yes it is a Optima 9 receiver. I live outside the U.S guys,i will use it as long as it's safe and there is nothing to worry about.
The next time i have a friend traveling to the U.S i will make plan to have it sent back
thanks for your help
Old 12-07-2010, 08:41 AM
Brendan Lugo
It's safe to use. The software update for the receiver is only so the add on telemetry sensor station will work with the receiver.
Old 12-07-2010, 06:42 PM
dredknot
Great,thank you
