Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
Aurora 9 charge socket issue
Old 01-09-2011, 08:04 AM
jauguston
Default Aurora 9 charge socket issue
My charger will not connect to the transmitter electrically to recharge the battery. The side contact seems to be too far from the center pin to contact the side of the charger jack. With a small insulated brass tube slid over the transmitter charge jack center pin and a "T" pin inserted to contact the side contact using small jumpers from the charger jack to the transmitter it will charge.
Can I remove the back of the transmitter without any unwanted surprises and access the charge socket and bend the contact in so it will make contact with the charger jack?
Jim
Old 01-10-2011, 07:57 AM
Brendan Lugo
Brendan Lugo's Avatar
Default RE: Aurora 9 charge socket issue
That will not gain you any more access to the charge receptical as it is a sealed unit. Are you using the wall charger that came with the radio or something else to charge the transmitter?
Old 01-10-2011, 08:28 AM
jauguston
Using the wall charger that came with it.
Jim
Old 01-13-2011, 07:13 AM
Brendan Lugo
Send it in, we'll have to replace the charge socket.
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
