Aurora 9 Update issue
ON, CANADA
During the upgrade from 1.07 to 1.08 my radio lost power. Now I am left with a radio that will not turn on or do anything. Anyone else run into this issue and is there a solution to this.
NY
RE: Aurora 9 Update issue
Ihave updated several times with no problems. Ialways make sure the battery is fully charged before Ido it. Isuspect it may have to go back to Hitec to get the basic software reloaded. But contact them at www.HitecRCD.com or by phone and they will tell you what needs to be done.
Good luck.
Good luck.
ORIGINAL: aceplant001976During the upgrade from 1.07 to 1.08 my radio lost power. Now I am left with a radio that will not turn on or do anything. Anyone else run into this issue and is there a solution to this.
Aurora 9 - Off/On Switch problem? TX Auto Saves (flash) Each Session's Programming and Trim Settings etc on Shutdown. Allow time to complete task before switching on again.
Alan T.
ON, CANADA
Tried the removing the battery trick with no fix. Ended up hooking it back up to the HPP-22 and reinstalling 1.06 and then working through to 1.08. Didn't think it would update without the screen but it did. All seems fine.
Just had this happen to me: loaded update 1.08 and tx now doesn't work. "Doesn't work" means power switch on, red light, yellow light, two beeps, red light, No display of anything. No signs of life. Why doesn't this thing have a reset button???
