Help with Hitec & Corona
Can I use Corona Model RP6S1 6ch 72MHz Single Conversion Receiver with my Hitec Eclipse 7??
I know this reciever does work with Futaba & Jr it is supposed to be a Synthesised receiver not sure how that works but will it bind with my Radio???
any help would be great
RE: Help with Hitec & Corona
ORIGINAL: DJ Chino Can I use Corona Model RP6S1 6ch 72MHz Single Conversion Receiver with my Hitec Eclipse 7?? I know this reciever does work with Futaba & Jr it is supposed to be a Synthesised receiver not sure how that works but will it bind with my Radio??? any help would be great
Set Eclipse on PPM&Negative shift (= same as Futaba setup).
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
Thanks Allan for the reply, I was gonna convert the Hitec to 2.4ghz but instead I bought the Corona so I can still use the 72mhz Radio what do I do wityh the Chrystal do I leave it in the radio????
ORIGINAL: DJ Chino Thanks Allan for the reply, I was gonna convert the Hitec to 2.4ghz but instead I bought the Corona so I can still use the 72mhz Radio what do I do wityh the Chrystal do I leave it in the radio????
If a synthesised Hitec TX module is to be used, channel of your choice can bedialled in, the synthesised receiver should then lock on to that channel.
Alan T.
