Kevlar fuse and 2,4 ghz
Do I need to take any precaution when using an Optima9 in a kevlar fuselage?? I range cheked it in arouns 150 m and no problems.
RE: Kevlar fuse and 2,4 ghz
ORIGINAL: gr�nnskolling Do I need to take any precaution when using an Optima9 in a kevlar fuselage?? I range cheked it in arouns 150 m and no problems.
The picturesattached:
Optima Transceiver (RX) - Installation RX & BODA Antenna FAQ, Volts & Range Test Results. {Regularily Updated with Q&A} are worth a view as well as Mike's review.
Carbon-Kevlar fuselage and Antenna is a typical related Q&A thread
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
Its the oposite in my plane, Vladimirs Model Graphite 2.(motornosecone). The front is combined kevlar/cf. The rear is kevlar. So I have put the antennas back in the fuselage, one unde and one over my rx battery. The range check was done just walking dawn the field wiggling my rudder, while my friend was cheking the plane.
