Aurora Mode change problem
Hi,
I just got my Aurora and it came as mode 1, but I am a mode 2 flyer.
I changed the stick ratchet over and set the mode in the radio software but the radio is still recognising:
J1 = Aileron correct
J2 = Throttle incorrect
J3 = Elevator incorrect
J4 = Rudder correct
When i changed to mode 2 in the radio I did see the graphic of the sticks change to the correct assignments but in the channel menu they are still set to mode 1.
I have power cycled the radio a couple of times now just to see if it needed to be reset to recognise the change but it made no difference.
I have updated the radio and module to the very latest firmware versions.
did i missing something here?
J4 = Rudder correct
RE: Aurora Mode change problem
ok i think i have worked it out.
the radio came with a default model already created (at mode 1)
when i created a new model with radio set to mode 2 - it created the correct mode 2 stick assignments on the new model.
i then switched back to the original model and it recognised that as mode 1 again, even though radio was still set to mode 2.
so it basically means - the stick mode stays with the model, regardless of the radio stick mode setting
not sure if this is a software bug or by design....wouldn't mind some clarification on that.
ORIGINAL: fjaust Hi, I just got my Aurora and it came as mode 1, but I am a mode 2 flyer.
J1 = Aileron correct J2 = Throttle incorrect J3 = Elevator incorrect J4 = Rudder correct
When i changed to mode 2 in the radio I did see the graphic of the sticks change to the correct assignments but in the channel menu they are still set to mode 1. I have power cycled the radio a couple of times now just to see if it needed to be reset to recognise the change but it made no difference.
and more under Hitec USA Support Forum Sticky:
Aurora 9, Spectra Modules & Optima Transceivers - FAQ & Undocumented Features
- Mixes, Setups,Tips. {Individual Links often updated
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
(quick search = Ctrl+F)
