Aurora 9 touch screen stoped working
HI all just wondering if there is a quick fix to my problem. I went flying today and after the second flight none of the icons worked. When the transmitter was switched on it allowed the yes to transmitt to work and go to the next screen but then nothing on this next screen works. The transmitter still transmitts OK two more flights after the problem arose with no problems. Yours Paul T
RE: Aurora 9 touch screen stoped working
ORIGINAL: Quigleywins HI all just wondering if there is a quick fix to my problem. I went flying today and after the second flight none of the icons worked. When the transmitter was switched on it allowed the yes to transmitt to work and go to the next screen but then nothing on this next screen works. The transmitter still transmitts OK two more flights after the problem arose with no problems. Yours Paul T
1. Remove battery cycle switch and replace battery (computer fix #1)
Aurora 9 - Off/On Switch problem? TX Auto Saves (flash) Each Session's Programming and Trim Settings etc on Shutdown.
Allow time to complete task before switching on again.- If problem remains -
2. Reload current or later firmware version.
Hitec HPP-22 2.4GHz Programmer - Manual, FAQ - How to install & Use Instructions (with screenshots).
Aurora 9 - Firmware Update V1.08 Manual.....Screen shots of the new displays plus additonal information.
Spectra Module - V3.01 update 18Apr11 - Manual.... Screenshots & further info.
3.Refer to local distributor:
MODEL ENGINES, Mr. Mike Farnan
44 DOWNING STREET,OAKLEIGH, MELBOURNE 3166, AUSTRALIA
61-3-9569-4440 [email protected]
ex Hitec USA Support Forum Sticky:
Aurora 9, Spectra Modules & Optima Transceivers - FAQ & Undocumented Features
- Mixes, Setups,Tips. {Individual Links often updated}
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
