3 Position Flaps
RE: 3 Position Flaps
The way I solved this was to set the left slider to control the flaps and the middle position be my 15 degrees then full up slider be my 0 degrees and set it up with EPA then the full down slider be my 45 degrees and use EPA again to set the desired throw.
