2.4 receiver antenna
i made a boo boo and cut my 2.4 receiver antenna in haft,what is the best way to join it or should replace the whole antenna
thank you
thank you
RE: 2.4 receiver antenna
ORIGINAL: dredknot i made a boo boo and cut my 2.4 receiver antenna in haft,what is the best way to join it or should replace the whole antenna thank you
. If tip's plastic sleeve appears separated at base and is a concern, secure with dab "Shoe Goo" or Heatshrink tube. as pictured.
(The base is soft solder and does not abraid the tip wire.)
NB: The length of the tip wire is critical, Do Not Attempt To Fly if the tip wire has been cut short or broken off.
Alternate antenna:
F1431 - Robbe RX aerial, 2.4 GHz 150 mm (R606-6014)
2.4G Receiver Antenna 150mm
Optima BODA antenna DIY Shorten or Replace and Alternatives.
In need, phone/email:
Hitec Warranty & Service
Note: Hitec USA only services North/South America and Canada. All other countries see appropriate distributor for service.
• If you are from a country that is outside North and South America, please contact the
Hitec distributor in your country for service.
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
