arm hold down screw
AZ
arm hold down screw
What size is the screw that holds the arm on for the metal gear servos? I have about a 1/2 dozen servos with no screws in them to hold the arm on.
RE: arm hold down screw
ORIGINAL: dirtybird What size is the screw that holds the arm on for the metal gear servos? I have about a 1/2 dozen servos with no screws in them to hold the arm on.
extract:
"Hitec Screw Set for Metal Geared Servos #55802 "Metal servo Screw Set (5 x short, 5 x long)".
Standard Machined Servo Screws 2.6mm x 6 mm & 8 mm Phillip-head (JIS) screws x 5 fit HS-225MG, HS-525MG, HS-625MG, HS-645MG, HS-705MG, HS-925MG, HS-945MG, HS-5245MG, HS5625MG, HS-5645MG, HS-5745MG, HS-5925MG, HS-5945MG, HS-5955TG, HS-5995TG, HS-5996TG, HS-5997TG, HS-5998TG, HS-7955TG.
Small machined screws, 2.3 x 5 mm Phillip-head (JIS) screws x 5, fit the HS-65MG, HS-81MG, HS-85MG, HS-125MG.
NB: Never use red loctite, in need if star washer is lost, Liquid Thread Lock used sparingly and ensure none remains in contact with plastic parts.
JIS - Japanese Industrial Standard"
</dt><dt>Servo - Horn Arm Spline Count and Inter Brand Compatibility might also assist with the various Hitec arm and spline sizes.</dt><dt>
more under
"Radio Systems, Accessories, Alterations and FAQ." at:
Alan's Hobby, Model & RC FAQ Web Links
</dt><dt>Alan T. </dt>
