eprom not saving my trims in Optic 6 perpotional
Hi there i m owning hitec optic 6. the problem i m faceing is when switch on the radio n set trims n turn off the radio n again back on all the trim that i set was waved off and s back on the previous setting
RE: eprom not saving my trims in Optic 6 perpotional
ORIGINAL: johnsmith122 Hi there i m owning hitec optic 6. the problem i m faceing is when switch on the radio n set trims n turn off the radio n again back on all the trim that i set was waved off and s back on the previous setting
then reset "bad" to factory default.
If new memory slot alsodoes not save all information input afterswitch is cycled,
refer direct to retailer/distributor for service..
Hitec Warranty & Service
Note: Hitec USA only services North/South America and Canada.
All other countries see appropriate distributor for service.
• If you are from a country that is outside North and South America, please contact the
Hitec distributor in your country for service.
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
