Minima 6L
RE: Minima 6L
ORIGINAL: schooner.cdn G'day,
Any word on when and where the 4 gram Minima 6L will be available to buy?
Cheers....
Cheers....
. New Minima Lite
"Look what just showed up! - Mike"
. "MAP: $42.99 , there is a new Minima 6S (Parkflyer) RX with top pins that you could remove the case from..
. or the existing Minima 6T. The 3.9g 6S will be $29.99 "
As it has just arrived in USA, allowing for holiday season, would expect into USA store any time soon.
Generally first to have new stock is Hobbyhorse, shoot them an email for ETA.
In need:
. Optima Receivers - Light Weight. Optima_6 LITE Transceiver, Minima 6E, 6T & 6L Lite Micro Receivers...
.. Minima are compatible only with Spectra Module V3.01 or higher. Caseless Weights for 6 & 7ch Optima Transceivers.
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
