Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
Hitec TX charge port polarity
Old 05-06-2013, 07:04 AM
bhady
Default Hitec TX charge port polarity
I recently purchased an older Hitec Laser 6 radio along with other RC gear from a guy getting out of the hobby. The wall wart charger for the Hitec radio is missing. Which wall wart chargers are compatible with Hitec transmitters? I currently have JR gear and am aware that JR Tx polarity is reversed from most other manufacturers. I don't want to fry any diodes or worse in the radio.
Thanks for your help.
B. Hady
Old 05-06-2013, 09:22 AM
AERORICH73
Default RE: Hitec TX charge port polarity
bhady: Believe you would be better served to just purchase a wall charger for this radio type since you will be using it for flying your planes until it wears out. In viewing the market, it might be a good idea to choose purchasing a field charging unit that can also be used at home. I have done this, and find it very useful in both cases without having two separate chargers. I am moving out of the NiCd use to the LiFe batteries which needs a different charging equipment. HobbyKing has some great buys in these charging devices, and can be used in both places. The LiFe batteries are smaller(two cell) types with more capacity. Using a UBEC, the higher voltages can be reduced to acceptable voltages so the RX does not get fried. I have two Laser 6's, and one Laser 4 along with Futuba stuff.
Cheers!!!
Rich
Old 05-06-2013, 12:09 PM
A.T.
ORIGINAL: bhady I recently purchased an older Hitec Laser 6 radio along with other RC gear from a guy getting out of the hobby.
don't want to fry any diodes or worse in the radio. Thanks for your help. B. Hady
Yes the polarity is reversed to JR. Either cut the wire and inert a plug and socket so as to revesre polarity as shown
attached picture, or buy a separate mutlipurpose unit.
This will also assist:
. Hitec Aurora, Eclipse, Flash, Optic & Prism series, Laser, FocusTX - Lipo and Field / Fast Charging
Much more information available below
"Radio Systems, Accessories, Alterations and FAQ" at
Alan's Hobby, Model & RC FAQ Web Links
Alan T.
Old 05-06-2013, 02:02 PM
bhady
Thanks for your help, I was pretty sure that Hitec center polarity was positive (opposite of JR), but wanted to be sure before I charged up the TX pack.
Bhady
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
