Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
5645MG Servos Continue to Move
Old 05-18-2013, 08:04 AM
stevehookem
Default 5645MG Servos Continue to Move
I purchased a plane from a local hobby shop that was built, finished and never flown. It is brand new. The plane has HT5645MG servos on all surfaces connected through a Smart Fly Power System Plus with two lipo batteries. The plane was set-up for and included a Futaba FASST receiver. I do not fly Futaba so I switched out the receiver for a Spektrum AR8000.
When I move a transmitter stick to it’s limit, the servo seems to go to the end and continue to move very slightly. This does not seem right to me! I’ve never had servos continue to move after the stick has stopped! I also have never used a programmable servo before. Is it possible that these servos were programmed and need to be reset for my receiver now?
Any help would be appreciated!
Old 05-18-2013, 03:01 PM
stevehookem
Default RE: 5645MG Servos Continue to Move
See my new thread. These servos were programmed for Futaba. I have questions in the other thread. Thanks!
Old 05-18-2013, 07:17 PM
A.T.
ORIGINAL: stevehookem
The new thread was Answered:
"Unfortunately you will need to borrow or buy any one of the Hitec Servo programmers:
Please refer
Alan's Hobby, Model & RC FAQ Web Links
sub section:
"Servo - Digital & Brushless Servo, Programmers and Software" e.g.
. Digital Servo Instruction Videos - Programming with HFP-10, HFP-20, HPP-21+, HFP-25
. Digital Servo Programming FAQ - Center & End Point - Adjust to Match TX
. Digital Servo Programming FAQ - Center Point May Vary - Why & Correction
. Digital Servo Programming FAQ - Center Point & End Point variance - Why & Correction
. Digital Servo Programming FAQ - Programmer is Preferable to using EPA & Trims on TX
. Digital Servo - Burnout. Cause & Prevention
. Digital Servo - Delayed or Slow Centering at Start up #01
. Digital Servo - High Resolution & Jitter - Why & DIY Cure #02
Also be wary of the different EPA settings between transmitter brands:
EPA, ATV, Dual & Triple Rates, Expo Differences & Caution includes ESC / BEC Set Up.
Much more information available under sub sections
"Glitches & Jitter in Receiver, Servo & ESC - Causes and Cures"
"Servo - Alterations, Calculators, Databases, Leads, Repairs, Convert to an ESC or winch & FAQ."
below
"Radio Systems, Accessories, Alterations and FAQ" at
Alan's Hobby, Model & RC FAQ Web Links "
Alan T.
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
