Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
Hitec HS-322HD compatible with Fuaba?
Old 10-22-2013, 01:02 AM
thomasrpp
Default Hitec HS-322HD compatible with Fuaba?
I bought a set of HS-322HD and I'm useing them with a Futaba 2.4Ghz and they are ratcheting, not smooth. Is this normal?
Old 10-23-2013, 07:46 PM
A.T.
Do not understand "ratcheting" but there should not be any problem unless of course the voltage is to high or to low.
. Jitter - Analogue Servo Arm (Horn) swings when Rx switched powered on.
. Jitter - Intermittant behaviour - Digital HXT & Bluebirds
. Jitter - High Resolution Digital Servo - Why & DIY Cure #01
. Jitter - High Resolution Digital Servo - Why & DIY Cure #02
Jitter - Is RX set for High Resolution Digital Servo or Analogue Servo where applicable
. Jitter - Servo Wag & Jerky Servo Movements
. Jittering servos on 6V - different brand voltages on signal line
. Servo - Operating Voltage Range - Burnout..
. Servo - Operating Voltage Range - (Hitec) usuage with NiMH, Lipol & A123 batteries.
Much more information available under sub sections
"Battery Care, Performance & DIY Battery Packs."
"ESC & BEC - Setup to prevent majority of all RF Problems, Brownouts & Crashes"
"Glitches & Jitter in Receiver, Servo & ESC - Causes and Cures"
"Servo - Alterations, Calculators, Databases, Leads, Repairs, Convert to an ESC or winch & FAQ."
below
"Radio Systems, Accessories, Alterations and FAQ" at
Alan's Hobby, Model & RC FAQ Web Links
Alan T.
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
