Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
Aurora 9 throtle cut issu
Old 01-21-2014, 02:49 AM
yak-54
yak-54's Avatar
Default Aurora 9 throtle cut issu
hi
i noticed a problem when trying to set the throtle cut i set the switch to H and set to ACT
now the throtle arm is not move at all when trying to move it but the throtle cut working
i switched to a different letter (switch) but it act the same
what do i do wrong
thank you
ilan
Old 01-21-2014, 02:54 PM
A.T.
Originally Posted by yak-54 View Post
hi
what do i do wrong
thank you ilan
Need to set switch on/off parameters, please refer to examples:
. Aurora 9 - Throttle Lock (Hold) & Transmit Yes-No Features & Use.
... How to use Icon and/or Switch method which operates when in transmit mode only.
. Aurora 9 - Throttle Cut & Idle Down Set-Up.. Throttle Cut Programming - Step by Step.
. Aurora 9 - Throttle Curve - Throttle Expo & P-Mix Set-Up. [NB: Hitec TX use Minus (-) Expo wherever JR/Spektrum use Plus (+) Expo]
ex Hitec USA Support Forum Sticky:
Aurora 9, AFHSS 2.4Ghz Module, Transceivers_Receivers & Telemetry
- FAQ, Setups & Tips {Individual Links often updated}
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
Old 01-21-2014, 11:49 PM
yak-54
yak-54's Avatar
thank to A.T
i will try it when return from work
ilan
Old 01-22-2014, 08:08 AM
yak-54
yak-54's Avatar
hi A.T
it doesn't work the throtle lock is INH nothing i do make the servo move except the the small movement to cut engine
ilan
Old 01-28-2014, 09:48 AM
MikeMayberry
MikeMayberry's Avatar
Make sure you activate the "adjust to trim" function in the menu which then allows you to set it with the throttle trim when the switch activates it.
Mike.
Old 01-28-2014, 10:51 AM
yak-54
yak-54's Avatar
hi mike
i will give it a try and let you know
ilan
Old 02-01-2014, 09:17 AM
yak-54
yak-54's Avatar
Hi to my friends
yesterday i found the problem why the throttle cut didn't work properly
the reason is that i didn't choose the on/off setting after selecting the switch
now it is working fine
many thanks
ilan
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
