Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
HELP! Aftermarket Battery Pack Wired Reverse Polarity
Old 06-20-2015, 07:53 AM
SrTelemaster150
SrTelemaster150's Avatar
Default HELP! Aftermarket Battery Pack Wired Reverse Polarity
I failed to double check the polarity of the aftermarket Tx battery pack that I ordered for my Optic 6/Prism 7X transmitters. The plug had a locating slot so I just plugged it in since it was impossible to get it backwards. The TX failed to turn on so I checked the polarity & sure enough, the plug was wired reverse polarity.
I plugged my original Hitec battery pack in & W/the switch in the "off" position it shows 9v & gives low battery beeps. In the "on" position, a;; seems normal. It seems that there is some "memory " of the reverse polarity present.
What can I do to correct this?
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
