hitech servo question
I have 2 brand new H/T/HS-82''s and one will NOT repete in the center.
I am using it in a delta wing HOG, so it must repete in both aileron and elevator functions.
I have double checked Tx and Rx for programming and all is set per manual
So what are my options ?
Cheers Bob T
Cheers Bob T
Brand new HS-82MG's may need to be cycled several times to help wear in. Sometimes they can be tight from the factory, you might also consider loosening the case screws about 1/4 turn. If all else fails, report back.
