Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
Flash 7 - dual aileron setup not working
Old 03-31-2017, 08:19 PM
SwampFlier-RCU
SwampFlier-RCU's Avatar
Exclamation Flash 7 - dual aileron setup not working
After a very good experience with my Aurora 9X, I bought a Flash7 for my smaller planes.
I am trying to setup a twist 40 with dual ailerons.
controls are set as follows:
Acro
2 Ailerons - normal mode
Rudder - Normal
Receiver Optima 6 ch - has a jumper on the site opposite the connectors
Servos are as follows:
Ch 1 - Aileron - J1
Ch 2 - Elevator - J2
Ch 3 - Throttle - J3
Ch 4 - Rudder - J4
Ch 5 - Aile2 - J1
Ch 6 - Battery
All surfaces work correctly, I reversed the throttle and Rudder for correct travel.
for the life of me I can't make the 2nd aileron servo move.
tried resetting the model... and fidging with the servos (they all work).
Please help.
P.S. I am using a 1400 mah NiMh battery with 4 cells is it enough to safely power the radio? And yes I switched the chemistry.
regards,
Patrick
Old 04-01-2017, 05:25 AM
GarySS
My Feedback: (13)
Should the other aileron be in the ch. 6 slot? Did you really set it up with the two aileron servo wing? ie. may need to start over and redesignate. What does that servo monitor screen show? These are just some thoughts that I have until the Hitec guys get back Monday.
Old 04-03-2017, 09:41 AM
Xpress
Xpress's Avatar
Check the servo monitor screen, if the indicator on Channel 5 is moving in conjunction with your aileron stick then the problem is the servo itself. If the indicator is not moving then try assigning Channel 5 to AILE instead of AIL2.
Old 04-08-2017, 02:13 PM
SwampFlier-RCU
Hello, I have checked all conexions and switched servos around. The servos are ok.
i used the servo monitor, the programing either using one or two ailerons works ok (bars move up/doen as they're supposed to.
apparently, ch1 on the receiver is not working. Will change to another receiver and seeif the problem is fixed or not.
regards,
Patrick
Old 04-11-2017, 05:00 AM
SwampFlier-RCU
Arrow It was the receiver!!
I am happy to inform that the culprit was the receiver. I swapped the optima 6 for an optima 7 and voliá!! It worked perfectly with the flash 7 on normal, with two ailerons and rudder nirmal, ailerons on channel ail 1and 5 ail2.
now a question... should I ditch the optima 6 or send it for repair?
Regards,
Patrick
Old 04-12-2017, 07:30 AM
Xpress
Xpress's Avatar
Get it to us, we'll take a look.
http://hitecrcd.com/support/warranty-service
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
