Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
A9+OPTIMA7+HS645MG glitching.
Old 01-07-2018, 05:50 PM
Default A9+OPTIMA7+HS645MG glitching.
Dear all.
I have an ultra stick with the following setup.
Aurora A9
Optima7 receiver
1800Mah NICD pack
07 HS654MG.
and a SAito FG30 on it.
I've flown this plane for 05 years and it was flawless.
All of suddenly it started to glitch when I fire the engine and go over 1/2 throttle.
When engine is off no problem.
When angine is under 50% it is ok.
After 50% throttle it simple goes crazy.
What could it be?
Please help!
Mauricio.
Old 01-08-2018, 08:45 AM
Originally Posted by mvarzoni
Dear all.
Aurora A9
Optima7 receiver
1800Mah NICD pack
07 HS654MG.
What could it be?
Please help!
Mauricio.
I would try swapping any y-harnesses and servo extension wires in case any of them has damage. I went through that on a big gasser a couple of months ago. Also, if you have your wires bundled up tightly with zip-ties or similar, spread them apart and see if that helps. It might be that either bad wires or tightly bundled wires are causing the problem? Good luck, that was a mess for me to go through and only trying all sorts of tricks solved it.
Old 01-08-2018, 09:05 AM
HSUKARIA,
Some fellows at field said same as you, they told me to replace extentions and even the on/off switch that is there since I first wired the plane.
IŽll follow your advice.
What is weird, is that the problem only occours when engine is over 1/2 thottle.
What if I conect an 3S lipo to the SPC port?
would it send more power to receiver/servos and overcome the interference?
Thank you.
Mauricio
Old 01-08-2018, 10:16 AM
HSUKARIA,
Thank you.
Mauricio
Not sure about that. Never tried it. The interference I was getting was going directly to the servo, not through the receiver. So, it varies. With these problems you might have to try everything possible. My problem also happened at higher throttle settings, like 1/4 throttle or higher.
I remember now that a guy at the field had crazy interference after flying the plane for years with no problems and it turned out to be the sparkplug cap had worn out. When he replaced the cap or ignition, the problem when away. So, I would make sure that the cap is pushed all the way in, if it is, try a different ignition module to see if the cap/boot is bad.
Old 01-08-2018, 11:06 AM
The CAP looks good, but those things are almost unnoticeable by naked eye.
The ignition is about 16 inches far from receiver and 10 inches far from throttle servo.
But IŽll try to isolate the mash and see if it helps.
Mauricio
Old 01-10-2018, 11:41 AM
Xpress's Avatar
Something is generating RF noise, you do not have the ignition plugged directly into the receiver do you?
The SPC port only powers the receiver circuit in the receiver, it will not power the servos.
Old 01-11-2018, 08:51 AM
It is,
SPARK PLUG --> IGNITION --> ON/OFF SWITCH--> BATTERY
No connection to the receiver.
The igniton box is placed more than 1 feet away from the optima7 receiver.
Thank you.
Mauricio
Old 01-11-2018, 09:13 AM
Where is it glitching?
On my Ultra Stick 30cc, it has only been in the flap servos. I swapped flap servos, and receivers with no remedy. The switches were brand new. I later swapped Y-harnesses and servo extension wires. That is what fixed it for me. But the interference was not coming from the receiver, it was directly going to the servos themselves. I even disabled the control function in the radio, but the flap servos continued to glitch when engine was above 1/4 throttle.
Old 12-11-2019, 11:45 AM
I replaced the ignition switch and battery and the problem went away...
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
