Feather Receiver
Feather Receiver
Mike I am using a Feather 4 channel FM receiver in a 20 to 40 size SPAD type airplane. I am running a Webra 20 size engine. I know the range is limited to about 600 to 700 safely and about 1000 ft max. I will be flying this airplane in at very close range most of the time.
Do you think the engine vibration will eventually be too much for this little reciever?
RE: Feather Receiver
Interesting that I just posted this reply to the question before your's http://www.rcuniverse.com/forum/Rece...1173874/tm.htm
The Feather is not suitable for that application. I would use a 555 or Electron as my top choices or the 04MB as a more inexpensive alternative. It also uses the same crystal as the Feather but has full range.
Mike.
Mike.
Is it because the Feather is limited by range or is it that the Feather can't withstand the vibration of a glow engine. Like I said, the airplane will rarely be more than 300 ft away from me.
