Trim problems on Hitec Flash 5
Mike:
Recently I have a problem with my trims, after a dozen of flights in my 4* 40 and after check my radio when I get airborne I found that the trims was completely moved from my last flight, this happens twice, I check the transmitter battery connectors and clean them; after that I do not have that failure again, is this normal? or I need to send my transmitter for a check?
Thanks in advance
Americo Cristini
Thanks in advance
Americo Cristini
