help with the Hitec Laser4
CT
It might be an easy fix, or has already been posted but couldn't find it.
The problem I'm having is I can charge the batt's on the tx but I can not check them
under load in the radio nor can I cycle them in the radio.
I have no mating plug for these batt's so I have no choice but to leave them in there,
and I dont want to splice jacks on here.
Maybe a diode or something simple to clip?
any help would be greatly appreciated.
thanks,
Mark
thanks,
Mark
RE: help with the Hitec Laser4
You can get the proper connector here: http://www.servocity.com
If you jump the diode you will void your warranty.
Mike.
Mike.
