Dual aileron servos?
One of 2 ways:
1) Simply connect both servos to a Y-connector and the Y-connector to channel 1 (Airlon) NOTE: Makes sure the pushrod connection to the servos are opposite of each other, either the connectors on both are toward the center of the wing or away from the center of the wing.
2) In the GLID mode you can set up FLAPERON features. Here is an excerpt from the manual:
"To access this function, first plug the right wing aileron servo in channel 1 of the receiver and left wing aileron servo into channel 5 of the receiver. The elevator servo is plugged into channel 2 of the receiver. In the MAIN EDIT MODE menu, you will find a function screen showing FLP2 to the right of the screen, and channel 1 is blinking. This indicates the function is activated and ready for programming. Using the Channel 1 trim key, you may change the value shown on the display to any positive or negative value. Doing so while the receiver system is turned ON will show you how this adjustment is working for you as the aileron servo moves with a change in the value. You move the aileron upward or downward as you wish."
