flash 5sx buddy bix compatabilities
Hi Mike
I'm a total beginner to rc flying. I have a flash 5sx which I'm told will connect directly to other manufactures txs with the hitec buddy lead (part no 58310).
Do you have a list of compatible units?
Also what will I need to do in the way of removing/changing crystals in my tx and the instuctors tx, and also in the rx?
Thank you very much
Thank you very much
Any Hitec or Futaba radio will work. You shouldn't change any crystals. If you are using the radio in your plane then the instructor will use the Flash 5 and you will use the other.
Mike.
Mike.
