Correct way to plug servos into receiver?
Hi Mike,
I'm nearing completion of my T-IFO kit, and have run across a minor problem regarding the wiring of my new Hitec Neon 55 FM receiver electronics. It seems as if the servo connectors can be plugged into the receiver in two ways. When facing the receiver with ch 1 on the bottom, do the connectors plug in with the ground wires on the left or on the right side of the connectors? Obviously plugging them in the wrong way would not be very good for the electronics.
Steve V.
Steve V.
The black wire should be toward the outside edge of the RX. Be aware that if the servo is plugged in backwards it cannot be damaged; it just won't work.
Mike.
Mike.
