Hitec Digital Servo thick wire but standard extention?
CA
I am installing the Hitec Digital Servos HS-5475HB and noticed that the wire on the servo extentions I am using are standard thickness but the wire used on the servo is thicker. Does this make a difference with how the servo will operate. Should I get the 22AWG thickness extentions or are the standard ones okey for these servos.
Digital servos, especially high power ones, can draw a lot of power hence the thicker servo wiring, I'd suggest you get some thicker extention leads.
FB
FB
