Q about the supreme 7 receiver w/shift select
NE
Mike,
Can you use the supreme 7 receiver with a futaba transmitter and older airtronics servos (not the Z connector)? Does the shift select effect the type of servo that can be used too?
Pondering changing the connectors or selling the servos and just buying a whole flight pack.
Thanks for any advice you can give.
GrumpE
GrumpE
You must make sure you have the proper shift RX for the TX and that the servos are wired to match the RX. The old Airtronics servos have the + and - wires reversed.
Mike.
Mike.
